2-Explorer
May 16, 2014
mapkey - how to force a toggle
  • May 16, 2014
  • 2 replies
  • 1111 views
Hello
In WF5 I recorded mapkey that turned off pre-highlighting.
I then followed some instructions I found to allow the key to turn on or off
the pre-highlight regardless of its current state - something like removing
a "1" from the config.pro text - or changing it to a negative value or some
such genius thing.
I wonder how the gurus learn this stuff.
Anyway, here I am in CR2 trying to toggle the display of a layer in a
mapkey. Basically, I'd like to assign F4 to turn on and off my "curves"
layer.
I'd also like to get my pre-selection highlight to behave the same way
again.
Is that still possible in Creo? If so, can someone remind me how to force a
toggle?
Thanks!
-Nate
Create two mapkeys - one that turns it on; one that turns it off.
Long ago, I recorded mapkeys for toggling various on/off controls in both states. I compared the two and found they were identical except the one that turned it on had a 1 in a certain spot and the one that turned it off had a 0. On a whim, I removed the 1 or 0, saved the text and gave it a whirl. I was a bit surprised, pleasantly, to find that it worked.
The problem you'll have with layers is that a layer can have 3 states, not 2 (shown, hidden and isolated). Because of that, I don't think you're going to get a single toggle mapkey to work. You'll need to do the trick David mentioned where the mapkey sets the state you want then loads a new config file that re-defines the mapkey.
