Jan 12, 2012 7:22 PM UTC
Mapkey Logging
Does anyone know of a clean way tolog the use of mapkeys? I would like to know if certain mapkeys are being used and how often.
The trail file does not necessarily capture the name of the mapkey depending on which method is used to initiate it (keyed in, menu/icon pick, Mapkey dialog box). I can add the @system to call out a batch file in each mapkey but that causes the system window to flash. It would be great to find a way that doesn't cause an additional window to flash or if there is an additional way to create logging somehow.
MikePhillips
Jan 13, 2012 3:25 PM UTC
What if you create a seperate batch file containing the logging code then
call that file from the mapkey using the START command. This command has a
run minimized switch.
[ Taken from the START help file]
TomU
Jan 13, 2012 4:07 PM UTC
You would still see a quick flash from the original system prompt. Using J-Link (as Steve wrote) would be much cleaner solution … if you’re using J-Link. We are not right now, so the next best solution seems to be to reduce the size of the initial system window before calling the start command to launch the actual logging script (with the /min switch). This way there is just a small flash in the corner instead of the entire screen. Here is what I came up with.
mapkey(continued) @SYSTEM\@echo off\nmode con:cols=15 lines=1\nstart /min \
mapkey(continued) c:\\ptc\\mapkeylog.bat mapkey_name;\
If someone wants to build a J-Link program, I’ll be more than willing to test it. ?
Tom Uminn
Systems Administrator
trans-matic Mfg.
616-820-2499
-<">mailto:->
Jan 13, 2012 4:41 PM UTC
Great idea but when the command prompt window starts it starts as the normal size. Then when it sees the mode con command the window changes size.
Plus the /MIN switch does not work in this situation for what ever reason.
Steve G
TomU
Jan 13, 2012 5:22 PM UTC
It's working on my machine (Windows 7 - 64bit). I have not tried it on others. The first time it runs it flashes the whole screen. Every time after that it only flashes a small window. Here's a screen shot of the small window (pause was added so I could capture it).
[cid:image002.png@01CCD1E5.8587FEA0]
Tom U.
Jan 13, 2012 10:28 PM UTC
Thank you for the new ideas. I have some new options to start testing now. Good to see that this may help some others with similar aspirations.
