Mar 18, 2015 8:14 AM UTC
Mapkey to toggle browser?
Hallo,
anyone could tell which are the mapkey strings to insert in the config.pro in order to have a mapkey that toggles the browser? (in Creo Parametric 2.0)
thanks
Mahesh_Sharma
22-Sapphire I
Mar 18, 2015 12:22 PM UTC
Tommaso,
You can try below mapkey, keyword is X.
mapkey X @MAPKEY_LABELopen/close browser;\
mapkey(continued) ~ Activate `main_dlg_cur` `BrowserOpenCloseChkBtn`;
tleati12-AmethystAuthor
Mar 18, 2015 12:41 PM UTC
I have to retrieve a little my first enthusiasm ...under certain circumstances it doesn't work and I really can't describe in which cases and for which reasons...
it's strange indeed, all I know is that in some cases, (before your suggestion some time ago I had put the browser icon in the bar under the ribbon (the keys Alt+5 are associated to it)) while Alt+5 works, the x button doesn't...
as soon as (and if) I can get further information I will keep you up-to-date
bye bye
Mar 19, 2015 5:50 PM UTC
I find that the recorded mapkeys are often flakey - they are prone to failing when the GUI state changes.
It takes a more investigation but it's worth finding the actual ProCmdxxxxxxx function that does what you want to do - calling these is usually more robust.
In your case, try the following mapkey:
mapkey X @MAPKEY_NAMEToggles between showing and hiding the Web Browser;@MAPKEY_LABELShow/Hide Browser;\
mapkey(continued) ~ Command `ProCmdBrowserBtn` -1;
(It's working right now in my Creo 2.0 M140 session , but note: in my configuration, I have my browser launch in a separate window.)
Good luck!
