Mar 13, 2015 7:55 PM UTC
Mapkeys
Has anyone encountered the problem that if Creo 3.0 crashes you lose all the mapkeys from your config.pro file? I've had this happen twice now.
2-Explorer
Mar 13, 2015 9:27 PM UTC
No, but that's what it may look like. Why do you think they are not there anymore? How did they get there to begin with?
cjonkman1-VisitorAuthor
Mar 16, 2015 12:28 PM UTC
Hello David,
Thank you for your reply.
How do I know they are not there anymore?
After the crash when I start Creo again and try to use my mapkeys they don't work. When I then look in my config.pro file where they are normally listed they are not there anymore. The comments we have added are still there but the mapkey sequences are gone.
How do they get there? When I record the mapkeys and save them from what I see they get saved in my config.pro file.
Cope
Dale_Rosema
Mar 16, 2015 2:28 PM UTC
Double check to make sure that you don't have multiple config.pro (s) and that they mistakenly got save to a different config.pro.
You can also check the date of the config.pro to see if it corresponds to the date you created the mapkeys.
Did you make back up config files when you added the mapkeys? I usually name the "old ones" config.pro.date (i.e. config.pro.20150316).
