MathCad xyz points to Creo Parametric
I am using Creo Parametric 7.0 7.0.3.0
Is there a way to push a matrix (3x51) of xyz points from MathCad to Creo Parametric?
1. A similar question was asked earlier:
2. From "Help Center" - "About the PTC Mathcad Prime Analysis and PTC Mathcad Prime Analysis Feature": https://support.ptc.com/help/creo/creo_pma/r7.0/usascii/index.html#page/model_analysis/bemod/About_Mathcad_Analysis_Feature.html#wwconnect_header
KenFarley
This is likely not the best place on the forums to get answers to this kind of question.
If you can't find a direct way to get the points from MathCAD to Creo, you could go about it in a more indirect way:
(1) Output the points to a file from MathCAD (Excel? Text file?) I don't know what your options are here since we don't use MathCAD.
(2) Use the X, Y, Z points to make a .ibl file. It's a relatively simple file format. Here's a sample:
open pointwise
begin section !1
begin curve
4.152635490642E+02 -4.494745914095 44.8
4.150263689969E+02 -4.475489942293 44.8
4.147892274691E+02 -4.455765001303 44.8
4.145521254190E+02 -4.435571073514 44.8
 (3) Import the .ibl file via Model -> Get Data -> Import and changing the Type field to "Ibl file (*.ibl)
It's not elegant, but it'll get the job done.
1.]
In Creo create datum point feature using Offset Coordinate System option and Save datum point list into pts file. You will get something like this ...
! DATUM POINT ARRAY DATA FILE
! Comment lines should begin with an exclamation mark (!).
! You may have as many comment lines as you wish.
! There must be at least one space between values.
! Enter values with respect to datum arrays' coordinate system:
!CARTESIAN coordinates:
! X Y Z
 0.00 0.00 0.00
 1.00 1.00 1.00
2.]
Create pts file using your x,y,z values and import it into datum point feature.
This is just a test of sending email notifications.
This is just a 2-nd test of sending email notifications.
