MDO - How to know the torque of a motion
- 2 replies
- 5417 views
- Translate All
I need to know the torque needed to move a mechanism, but I don't know to simulate this motion on MDO.
I have the machine assembled with mechanisms. It consists of a "sliding table" assembled as a slider, and the motor's gear as a pin. The "table" is an assembly wich contains the motor and a solid to simulate the mass of the parts wich should go on the table.
The motor's shaft has a gear on it's lower part, wich is the gear of the rack-pinion mechanism. To simulate this mechanism (and to relate the linear motion of the table with the rotation of the motor's shaft) I created a Rack-Pinion Gear connection between the slider and the pin.
What I want to do is to simulate a linear motion of the system, and measure the torque needed to generate this motion. But I don't know exactly how to do it.
* As my assembly has a mm-kg unit system, I've assembled it into an empty meter-Newton assembly, to create the MDO simulation and get the torque results on Nm.
What I do is I create a Servo Motor on the slider connection, to make the mechanism move. I created a linear Servo of 0.5 m/sec. I created some Measures: velocity, acceleration and position of the slider, and rotation and torque on the shaft of the motor.
I created a Dynamic analysis to make the system move, and measure all these things, and the torque result is 0.
I guess that the torque should be given by all the oposing forces to the movement (mass, friction...), but if I activate them, the results are the same. Besides, I don't know which friction values I should use on the slider and the pin connections, but changing these values doesn't seem to affect the results...
Could anyone help me with the configuration of this MDO analysis to calculate the torque on the shaft?
You can find the assembly attached. It's made on Creo 3.0. The main assembly to open is "conj_simulacio.asm", so you can see the full mechansim.
Thank you very much!
