Aug 5, 2014 11:51 AM UTC
Mechanica hangs at the end of the analaysis???
I am just about to blow a gasket because of Mechanica. After having numerous problems with creating a mesh and ignoring a mesh, I am now having problems with Mechanica hanging up right at the end of an analysis that takes 4 hours to run! It gives no errors and doesn't even really crash, but it won't get any further than "Begin Strain Energy Calculations" on the second pass. I have tried letting it sit over night and I have even tried running it from the command line using a batch file, but it always gets to this point and hangs up.
The thing that is really irritating is that I have 8 loading conditions on the same model and 5/8 run without issue.
Anyone know what causes it to hang like this or what I can do to get it unstuck?
Aug 5, 2014 11:55 AM UTC
Can't help you, but you have my sympathy.
This is typical of Mechanica. When it works it's bl**dy brilliant. When it decides not to work it's incredibly frustrating, especially because (as you say) it seems to work fine in some situations and then suddenly not work in apparently similar ones, for no apparent reason.
Aug 5, 2014 12:03 PM UTC
Not sure if it is related, but when I stop the analysis and try to save the model it says "Mechanica model save error".
Aug 5, 2014 12:44 PM UTC
They are under different load sets because I can't keep up with them otherwise.
2-Explorer
Aug 5, 2014 1:13 PM UTC
What do you have for Geomchecks?
Any warnings or errors when you mesh the model manually?
Aug 5, 2014 8:54 PM UTC
No errors and only warnings about angles between edges.
