Oct 8, 2013 1:40 PM UTC
Mechanism real time animation, CPU, logs, batch, UI
Is there a way to animate results in real time?
Animation is slow even with the speed slider bar hard over to the right in the animation dialogue.
Can we use more cores if theory/software architecture permits? about 2.5 of 12 cores used.
Can we have rudementary log files for review? Basic information such as CPU and elapsed time, User defined measure max/mins for example, start and finish time, results dir path and size, file sizes, memory usage, an analysis description field ...
Could we batch solutions as we do in Mechanica?
Could the UI be released during an analysis as is the case with Mechanica?
