Feb 22, 2013 1:16 AM UTC
Message that the disk is full and the calculation stops in Simulate
To begin:
Windows 7 pro 32 bit.
My disk space is 1.33 TB 1.63 TB of
I am an administrator, I have all the rights and I have nothing limited.
Concerns creo simulate two
Example:
I'm in a directory defined for a piece
I run the simulation calculation, a small piece.
I change my piece and I raise the calculation several times.
And suddenly I get the message that the disk is full and the calculation stops.
I created a new directory, I transfer the piece to calculate this new directory and I can easily do the math.
Should make adjustments in the config.pro.pour avoid this problem.
Cordially.
Denis
2-Explorer
Mar 1, 2013 9:06 PM UTC
Denis,
Can you post a text copy of your .rpt file? It will be in the directory that was created when you started the analysis.
Mar 2, 2013 11:56 AM UTC
it might be the case of ram or virtual paging space.
Mar 2, 2013 7:00 PM UTC
Thank you for your answers.
As previously stated, I emptied my repertoire tried to solve this problem, therefore I do not have the fichier.rpt the problem.
I just copy the game to translation and research.
Designing abnormally terminated.
Error reading disk solver; probable reason:
insufficient disk space or insufficient permissions on files / directories.
For more information, refer to the
following documentation:
section: "Running Standard Design Studies"
topics: "Using Multiple Working Directories"
"Managing Disk Space Resources"
Cordially.
Denis
Mar 7, 2013 5:05 AM UTC
Is it possible to check in workstatin of higher ram? or you can change the paging file size> control panel >system> advance system settings> advanced> performance otions> advanced> virtual memory change. Will it help?
Jayanta Sarkar
