Method Server not starting
I am new to PTC and I was following the customization guide for creating a new class called 'Pet' on page 53.
I did not complete the entire process and then stopped the winchill and the machine was shut down.
Now, I am not able to start my Method Server..
I get the below error log:
Mon 7/8/13 15:53:57: main: wt.services.ManagerException: wt.util.WTException: (wt.pom.pomResource/0) wt.pom.PersistenceException: A persistence error occurred. System message follows:
Mon 7/8/13 15:53:57: main: Nested exception is: (wt.introspection.introspectionResource/6) wt.introspection.WTIntrospectionException: An introspection error has occured. System message follows:
Mon 7/8/13 15:53:57: main: Nested exception is: java.lang.ClassNotFoundException: com.acme.Pet
Mon 7/8/13 15:53:57: main: Nested exception is: (wt.pom.pomResource/0) wt.pom.PersistenceException: A persistence error occurred. System message follows:
Mon 7/8/13 15:53:57: main: Nested exception is: wt.util.WTException: (wt.pom.pomResource/0) wt.pom.PersistenceException: A persistence error occurred. System message follows:
Mon 7/8/13 15:53:57: main: Nested exception is: java.lang. com.acme.Pet
Mon 7/8/13 15:53:57: main: at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
Mon 7/8/13 15:53:57: main: at java.security.AccessController.doPrivileged(Native Method)
Mon 7/8/13 15:53:57: main: at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
Mon 7/8/13 15:53:57: main: at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
Mon 7/8/13 15:53:57: main: at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
Mon 7/8/13 15:53:57: main: at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
Mon 7/8/13 15:53:57: main: at java.lang.Class.forName0(Native Method)
Mon 7/8/13 15:53:57: main: at java.lang.Class.forName(Class.java:169)
Mon 7/8/13 15:53:57: main: at wt.introspection.ClassInfo.loadClass(ClassInfo.java:1835)
Mon 7/8/13 15:53:57: main: at wt.introspection.ClassInfo.getConcreteClass(ClassInfo.java:1003)
Mon 7/8/13 15:53:57: main: at wt.pom.EmptyTableManager.queryTables(EmptyTableManager.java:517)
Mon 7/8/13 15:53:57: main: at wt.pom.EmptyTableManager.queryTables(EmptyTableManager.java:489)
Mon 7/8/13 15:53:57: main: at wt.pom.EmptyTableManager.findEmptyTables(EmptyTableManager.java:557)
Mon 7/8/13 15:53:57: main: at wt.pom.EmptyTableManager.populateCache(EmptyTableManager.java:131)
Mon 7/8/13 15:53:57: main: at wt.pom.EmptyTableManager.access$100(EmptyTableManager.java:83)
Mon 7/8/13 15:53:57: main: at wt.pom.EmptyTableManager$AllManagersStartedEventListener.notifyVetoableEvent(EmptyTableManager.java:658)
Mon 7/8/13 15:53:57: main: at wt.events.StandardKeyedEventBranch.intDispatchEvent(StandardKeyedEventBranch.java:320)
Mon 7/8/13 15:53:57: main: at wt.events.StandardKeyedEventBranch.dispatchVetoableEvent(StandardKeyedEventBranch.java:229)
Mon 7/8/13 15:53:57: main: at wt.events.StandardKeyedEventDispatcher.intDispatchEvent(StandardKeyedEventDispatcher.java:286)
Mon 7/8/13 15:53:57: main: at wt.events.StandardKeyedEventDispatcher.dispatchVetoableEvent(StandardKeyedEventDispatcher.java:215)
Mon 7/8/13 15:53:57: main: at wt.services.StandardManagerService.intDispatchVetoableEvent(StandardManagerService.java:406)
Mon 7/8/13 15:53:57: main: at wt.services.StandardManagerService.dispatchVetoableEvent(StandardManagerService.java:302)
Mon 7/8/13 15:53:57: main: at wt.services.StandardManagerService.performStartupProcess(StandardManagerService.java:184)
Mon 7/8/13 15:53:57: main: at wt.services.StandardManager.startup(StandardManager.java:459)
Mon 7/8/13 15:53:57: main: at wt.services.StandardServicesHandler.start(StandardServicesHandler.java:44)
Mon 7/8/13 15:53:57: main: at wt.method.MethodServerMain.run(MethodServerMain.java:423)
Mon 7/8/13 15:53:57: main: at wt.method.MethodServerMain.main(MethodServerMain.java:274)
Mon 7/8/13 15:53:57: main: FATAL : wt.method.server.shutdown - Stopping services...
Mon 7/8/13 15:53:57: main: INFO : wt.method.server.shutdown.services - All managers shut down.
Mon 7/8/13 15:53:57: main: FATAL : wt.method.server.shutdown - MethodServer stopped
I did some research on the internet and it shows that if we do not "Compile all Java sources created by system generation" then the system will be "missing the class files to match the registry properties". (http://xiaogyiy.iteye.com/blog/787300)
I do not know if this is true, and if it is then how to correct this mistake.
Please help me to start the method server (or is re installation my final option?).
Kazi
kkaziAnswer
I resolved this error by searching all files containing the word 'Pet' in their name (found a class info file in com.acme) or in the content and deleting them.
I found a file in Windchill\codebase\descendentRegistry.properties.. It had the entry which was causing the error. I removed that entry and upon restarting the method server booted successfuly !
kkazi1-VisitorAuthorAnswer
good to hear that you could solve the (Windchill Method Server) problem by yourself.
Please note that this forum is intended for "Creo Elements/Direct" Software only.
Max
Hello, there is a video of training for example from the documentation
https://www.youtube.com/watch?v=-14BSAwteVw&list=PLjm4gmbLQwoeqQSP7xUhCnInGknqTBAZV&index=2
