Mar 22, 2016 10:45 AM UTC
mmweb - WebConfig.getInstance(context) - what's the context introduced with 19.1
CED Model Manager mmweb customization needs to use WebConfig.getInstance() to retrieve some info through the XML configuration file.
With 19.1 introduction WebConfig.getInstance() changed to WebConfig.getInstance(context).
Is there anybody able to explain what's the context parameter, and how to set it properly in order to re-use WebConfig.getInstance(context) to retrieve XML configuration information.
Mar 30, 2016 4:58 PM UTC
First quick answer - retrieved from my Netbeans IDE
     * Get the current WebConfig instance.
     * @return the WebConfig instance.
     * @see WebConfigFactory#createInstance(ServletContext)
    public static synchronized WebConfig getInstance(final ServletContext context) {
lfortner14-AlexandriteAuthor
Mar 30, 2016 6:01 PM UTC
Thanks Max,
And this is precisely my question: how to use this method, and what's the ServletContext context I should use to retrieve such a WebConfig. Have you a use example of this method?
Mar 31, 2016 10:45 AM UTC
Well, from inspecting the sources with Netbeans, I don't get a clue 😞
I suggest the following Actions (in this order):
- Log A Case with PTC Support
- Debug the WebService - not easy, but can be done
