Model Tree Column Width Dragger
Hovering over the column separators inside of the Creo model tree creates a context-sensitive dragger, allowing the user to resize the column:
Does anyone know how to enlarge this area so it isn't so frustrating to click?  On a high resolution monitor, clicking an area the size of one pixel can be difficult.
Luke
StephenW
StephenWAnswer
That's too bad. Only other thought is I one time had issues with selections and it was due to a mouse speed or resolution setting in my mouse settings. But that corresponded with a specific change I had made to the settings.  If you've changed mouse or adjusted the setting recently, maybe that is a potential solution.
Other than that, I've got nothing!!
StephenW
I used to have the option PICK_APERATURE_RADIUS set to a value other the default which is now 7. I don't remember what that reason was.
I'm not sure this helps in your situation for the model tree column size, but it may. Be aware, it will adjust other pick selections, maybe negatively.
lukerb105-Regular MemberAuthor
Thanks for the response.  It would appear this setting doesn't have any effect, even when using very large values like 100.  Maybe it pertains to a specific context in the software.  There is a line for it in the config options document.
StephenW
StephenW23-Emerald IIIAnswer
