Aug 10, 2016 2:03 PM UTC
ModelCHECK batch mode
I have 2 questions about this process.
What items can be fixed in batch mode
# Automatically update errors in models when run in BATCH
MODE_UPDATE YN Y Y N N
Layers
Parameters
Can you force ModelCHECK batch mode to run a regeneration after it fixes the models?
Current issue, batch mode runs, fixes models, saves model, but does not update the parameter mc_errors
I need another options to run a regeneration after the fixes happen to update the param then save model.
Aug 10, 2016 4:16 PM UTC
Try with MU_REGENERATE in the config_init.mc file. That triggers regeneration of the model during model update, which is made available using another option MU_ENABLED in the same config file.
Aug 10, 2016 6:03 PM UTC
I added these to the bottom of the file, did not see a difference. Do they need to be in a specific location in the file?
Aug 11, 2016 3:28 PM UTC
No, just make sure they are correctly read in by the modelcheck GUI inside Creo Parametric.
