ModelCHECK in regenerate mode does not work when stoplight is clicked or changes are made in feature
Model CHECK in regenerate mode works perfectly fine when following option is clicked:
But when I try to use the stoplight (which is shown below) to regenerate model, the Model CHECK regenerate window does not pop up.
Its also does not pop up when the Auto regenerate is triggered caused by a change from the feature tree. Even though the following message shows up "TESTPART regeneration completed successfully"
Is there any way I can trigger Model CHECK in regenerate mode by "stoplight" option and "change in feature tree" option as well ?
If ModelCheck does not get triggered by those regeneration methods, then it must be something in the coding of the MC Regen call. Probably it isn't in the regen itself but in the activation of that button push that triggers the MC run.
@Prasad_G Can you open a case with Tech Support? This sounds like a bug to me.
Prasad_G12-AmethystAuthor
Thanks for the reply @lwestbrook and @BenLoosli .
Will reach out to Tech Support.
