Sep 10, 2026 6:06 PM UTC
ModelCHECK Report/Metrics Directory
Using Creo 10 on Windows 11.   How do I write the metrics and reports to a user folder using the config_init.mc file?
Target Directory
“C:\data\<username>\Creo10\mc_report”
Some details that may help.
1) We do set a username system variable that I could key into.
2) The “Creo10” folder level is the working directory which we set.
Do I focus on the NT or not labeled options.
  • DIR_REPORT_NT or DIR_REPORT
Thanks for your advise.
Mahesh_Sharma
22-Sapphire I
Sep 11, 2026 12:19 PM UTC
Hi ​@N.Barnes
Reports and Metrics to a custom Directory is possible by defining DIR_METRICS and DIR_REPORT.
DIR_REPORT - To store reports.
DIR_METRICS - To store metrics files.
Reference Article
I hope this will help.
Thanks.
N.Barnes15-MoonstoneAuthor
Sep 16, 2026 7:29 PM UTC
Does the user variable have to be ONLY at the start of the line or can it be in the middle?
The article has this….
  • User may define the path with system variables.
    • E.g. $USERPROFILE/AppData\Roaming\PTC\ProENGINEER\TEST
I have C:\data\$USERNAME\Creo10work\Metrics_Files, but that is not working?
I notice the the article has the slashes changing in the string, do I need to do that too?
Mahesh_Sharma
22-Sapphire I
Sep 17, 2026 7:27 PM UTC
Try changing the slash after Username to forward as C:\data\$USERNAME/Creo10work\Metrics_Files
Sep 14, 2026 12:39 PM UTC
When I set up ModelCheck, I put those folders on a shared drive so all users are writing to a common folder that everyone can see.
Sep 18, 2026 9:07 AM UTC
I have created a separate folder for ModelCheck with identical path names, on all systems using Creo.
e.g.
D:\Creo_Data\Modelcheck_Reports
Thus, there is no conflict of write access and everyone knows where it is.
The only disadvantage is that it is not on a network hence the design checker would not have the last report on the model or the drawing.
Knowing, what we know is just a fistful of Earth, brings in humility.
