ModelCheck reporting on lack of a parameter
When we run ModelCheck, I have it set to check for certain parameter values. This works fine if the value is not in the list or the parameter is not designated to Windchill. With some older files from another design group that we have inherited, the parameter may not be in the file.
Is there a method to report that a parameter is not in the file?
These will report if the parameter is not designated or the value is not on the list.
PRT_PARAMETER CLASSIFICATION STR EQ LIST_CLASSIFICATION
PRT_PARAMETER CLASSIFICATION NONE EQ PDM
We are running Creo 9.0.5.0 with Windchill 12.0.2.10. ModelCheck files were created with Creo 7, but I don't see any significant changes in the setup files.
@BenLoosli  THe only one I can think of is the checks file option EXTRA_PARAMS YNEW N N N N N
