8-Gravel
ModelCheck Setup
I am using Creo Parametric Release 10.0 and Datecode10.0.8.0
While trying to set up ModelCheck, the instructions say to go to "To configure the Creo ModelCHECK settings, click File > Options > Environment > ModelCHECK Settings." However, that menu option (Environment) is not available to me.
How do I get File > Options > Environment to become available to me?
Here are the errors that I faced
None
    Mahesh_Sharma
    22-Sapphire I
    Hi @jm_01_10512334
    Environment option to configure ModelCHECK settings is in Creo Parametric Options window. Is it not there as in below image in your installed Creo?
    Are you an administrator? There is a ModelCheck setting that will block normal users from being able to modify the files.
    8-Gravel
    Thanks, Ben.  I have no clue how to check for that...  (Obviously, I am not.)
    Was ModelCHECK installed with Creo Parametric?  Look for <Creo Load Point>\Common Files\modchk.
    8-Gravel
    Yes, that folder is present.
    Mahesh_Sharma
    22-Sapphire I
    Hi @jm_01_10512334
    8-Gravel
    I must be getting old.  I overlooked that for hours, but there it is - right in front of my face. 😲🙄
    Thanks @Mahesh_Sharma
