Modify dimensions of a sweep part after finalize/saving...
- 5 replies
- 2663 views
- Translate All
What is the succession of steps to modify a sweep part after the part was finalized and saved?
I will attach a simple part as an example, I want to change the 200 mm length of the sweep to 350 mm (for example).
I have tried going to Edit Definitions, but no matter what I do, I cannot get all the way back to the dimensions that I need to modify... I want to be able to change the dimensions similarly as one can do that for an extrude feature (for example), where you edit after the initial creation and modify the depth of the extrude, or the length or width associated with it. When it comes to a sweep feature, I cannot make it all the way deep to the initial curve sketching level. I am using Creo 3.0.
Thank you, Colin.
