Modifying the configuration options in the config configuration file can solve this problem.
I am using Creo Parametric Release 4.0 and DatecodeM150
In compatible design, the electronic side will name the compatible devices together (such as PK...RK...PRT, which should actually be two devices PK...PRT and RK...PRT), and import EMN into The device cannot be found after Creo. PTC Ronggong (Hui) said that modifying the configuration options in the config configuration file can solve this problem. Which configuration option should be modified?
Translated text from Chinese to English using Google translate. By Community moderation team.
Subject: 在config配置文件中修改配置选项可以解决此问题,请问是修改哪个配置选项
Body: 兼容设计时,电子那边将兼容使用的器件连起来命名(例如PK...RK...PRT,实际应该是两个器件PK...PRT和RK...PRT),将EMN导入到Creo后找不到这个器件,PTC荣工(辉)说在config配置文件中修改配置选项可以解决此问题,请问是修改哪个配置选项?
