Multiple Licenses on Single Server
We have 6 licenses that are on maintenance and 4 that are not.  Right now, they are all capable of running up to Creo 3.
The question is, can we (how do we) use a single server to run both of the sets of licenses?
Our new license pack should only include the 6 that are on maintenance, how do we reach the other 4?
Are any of you already doing this?
(Just Creo, no Windchill etc.)
MIke
BenLoosliAnswer
Your license file should include all 10 licenses on 2 lines.
One line should show the 6 undermaintenace and valid for Creo 4.
The second line should have the 4 expired licenses and only goo through Creo 3.
BenLoosli23-Emerald IIIAnswer
Ok, I was hoping this would be easy, but our VAR was telling us we need to split them to different servers.
Don't know why they need to be split.
These are the lines from my single license file:
#PROE_Flex3C             2    Creo Enterprise SE (formerly Pro/ENGINEE   Wildfire 5.0 & Creo Flt Lic  perm
#PROE_Flex3C             8    Creo Enterprise SE (formerly Pro/ENGINEE  Creo 2.0 Flt Lic  perm
#PROE_Flex3C             7    Creo Enterprise SE (formerly Pro/ENGINEE  Creo 4.0 Flt Lic  perm
Since I am still on Creo 2, I have 15 licenses. When I go to Creo 4, I will only have 7.
But my 2 for WF 5 and 8 for Creo 2 will still be valid and used IF I exceed the 7 AND run one of the older versions of Pro/Engineer.
