Nov 4, 2011 6:06 PM UTC
No valid license for Creo Elements/Direct Modeling Express 4.0
I have installed Creo Elements/Direct Modeling Express 4.0, but cannot gat past the splash screen. I am connected to the internet, I have NET framework 2.0 SP2 and the firewall is turned off - any ideas how I can get the program running? It has never worked
fhuslikAnswer
Nov 26, 2011 4:16 PM UTC
Answer to my own post:
The write access to the registry key:
HKEY_CURRENT_USER\Software\CoCreate\OneSpaceModelingPE
failed.
Just set the permissions in regedit to allow it to you and the system to write the key.
Then restart Creo.
Nov 4, 2011 6:08 PM UTC
If it helps, I also get the following error message every time I try to run the program:
OLAPEPP has encountered a problem and needs to close. We are sorry for the inconvenience
Nov 4, 2011 6:18 PM UTC
You forgot to mention what Windows OS are using.
Nov 4, 2011 6:23 PM UTC
Sorry -
Windows XP Home SP3
Dual Core 1.73GHz
2Gb RAM
