Sep 20, 2012 2:01 PM UTC
number of info lines in main window
Is there a config.pro option for setting the number of lines for the information output area (dashboard?) of the main winow?
It comes up with 4 visible lines, but I always drag it taller so I can see 6 or 8 lines.
thanks
Sep 20, 2012 2:32 PM UTC
visible_message_lines <#>
Sep 20, 2012 2:34 PM UTC
If you do a right click in that area, you can open the whole info data message log.
Enjoy,
Ronnie Shand
Sep 20, 2012 2:41 PM UTC
Used it.... doesn't do anything
Sep 20, 2012 2:45 PM UTC
I’ve had the same frustration. I always get 2, no matter the config setting. And, many messages require 3 lines.
Doug Schaefer
Sep 20, 2012 3:04 PM UTC
Hmmm... strange, it's always worked for me.... Currently, I have it set to 3, and I see 3 lines plus 1... This is in wf4, M140... I also have my config.win setting to show the "dashboard" on top...
Sep 20, 2012 3:08 PM UTC
Does not work for me either. My config was set for 4 which I have, but I changed it to others higher and lower tried it and it made no difference. Strange…..maybe config.win overrides it but I did not check into that nor do I care that much so I am done thinking about it.
