Nvida Nview vs benchmark
Interesting that most of the difference is not in the graphics related tasks.
What card & driver are you using?
    Precision M4800
    Intel(R) Core(TM) i7-4940MX CPU @ 3.10GHz
    Total Physical Memory: 32,673 MB
    NVIDIA Quadro K2100M
    Version 347.88
    OS Name: Microsoft Windows 7 Enterprise
    OS Version: 6.1.7601 Service Pack 1 Build 7601
    64_Bit
    M140
    David Haigh
    I also picked up nearly the identical M4800 for traveling. From the
    factory, it was a huge disappointment, lockups, tons of things in event
    viewer that looked bad, and a blue screen. I was going to return it but
    could not find something to purchase that looked better to me.
    I decided to try a minimal vanilla Win7 install from scratch. I did that
    and it looked much better. I then installed the drivers from the Dell
    support site and things went pear shaped again. I then stumbled upon a Dell
    document with instructions for the exact order to install drivers on the
    M4800. Starting over again from scratch with a Win7 install, then the
    drivers that 'appeared' mandatory it has been working well, like a different
    machine. No Nview. The Dell power items were a major source of problems so
    I did not install that either.
    John
    I never knew you could remove just nview. It used to work well (several workstations and OS's ago), I really liked having multiple virtual desktops. Not as important now with dual screens but I would still use it if it didn't hose up. I will delete is since I can't use it. Surprising how your machine was faster without the graphics driver than with the driver and nview. I swear software has become so bloated and layered today that we are wasting 90% of the CPU cycles.
    In Reply to David Haigh:
    Precision M4800
    Version 347.88
    64_Bit
    M140
    David Haigh
