May 6, 2014 3:21 PM UTC
Nvidia drivers 32 bit
Can creo work on a Dell Latitude E6430 LaptopRunning windows 7 32 bit with a NVIDIA NVS 5200M.
    May 6, 2014 4:34 PM UTC
    Welcome to the forum Mark.
    I suggest you only use the Dell drivers. I have a Precision laptop with an NVidia card and only the Dell drivers work properly. NVidia drivers directly from NVidia cause serous artifacts in auxiliary windows regardless of version.
    mwatson-21-VisitorAuthor
    May 6, 2014 5:04 PM UTC
    Thanks, maybe I should go for a Precision m4800 and change the opertaing system down to 32 bit!
    May 6, 2014 5:43 PM UTC
    Why do you need the 32 bit as opposed to 64? 64 allows much more RAM and will help to future-proof your machine.
    Jun 20, 2014 8:22 PM UTC
    Hi Mark,
    I'm not sure if you already purchased you machine or if you are still shopping but here is Platform Support page:
    For Creo Parametric 2.0:
    • From the Table of Contents, click "Certified and Support Graphics Cards" then click the manufacturer from the "Workstation Vendor" column.
    If a machine configuration is not listed on the Platform Support page it does not mean neccessarily mean there will be any issue. Many untested machines perform just fine (sometimes better ) but the specific ones listed have been tested and certified by PTC and will be supported.
