Jul 24, 2013 8:20 PM UTC
NVidia OpenGL Driver
Two of our users with the same exact machines are getting the error below when trying to print within Creo view 1.0 to a Xerox wide format printer.
"Your hardware configuration does not meet minimum specifications needed to run the application The application must close."
They said it only stated happening recently. Printing works fine if they use other application such as Adobe. Please help! - Thank you
Jul 25, 2013 3:14 AM UTC
What makes you think it is an NVidia driver issue?
Jul 25, 2013 3:12 PM UTC
I am assuming it's a driver issue because I tested it on 3 identical machine and gave me the same error. I also tested replacing the video card (Quadro 2000) with a different NVidia card (Quadro FX 1700) and it worked just fine.
Jul 25, 2013 3:30 PM UTC
Ah... very good. Have you tried downgrading your video driver for the Quadro 2000?
Video drivers and PTC simply don't get along. I am not sure where the core of Creo View comes from, but if it is written on similar code to Creo Parametric (Pro|E) then it comes from UNIX. I have had nothing but trouble with Pro|E and graphics drivers over the many years.
Recently, I found that the NVidia drivers from their site don't work. I have a Dell laptop and I could not update the drivers until Dell published them. Things were simply too unstable with the NVidia drivers. I have the Mobile Quadro 3000M in my Dell Precision.
You might also try a different printer driver, but I suspect that is not the problem. It is something with Creo View that is crashing when it prepares the print file. If you have maintenance with PTC, I suggest creating a customer support case. If you don't have access to this function, you might talk with your IT person to initiate the case.
Welcome to the forum, Sherwin. I hope you can get this resolved.
