2-Explorer
Jun 30, 2011 9:37 AM UTC
NVS295 - excruciatingly slow re-draw
Full marks to David Guillette's son the computer gamer:
> Hi John, this may or may not fix your drawing lag...I have seen mixed
> results.
> Please, go armed with the thought "everything in this e-mail may be
wrong".
> ....but....It's what worked for me and may be worth a try.
> 1st drivers are key...and...newer is not better when it comes to
> pro/Engineer.
> if nView is running...shut it off, use windows to set up your displays.
> find your way into nvidia control panel...Manage 3D settings....
> set Global preset to "Base profile"
> set multi-display to "Compatibility performance mode"
> (see the snapshot below)
For us, the last setting made all the difference.
Great stuff!
Jul 5, 2011 3:30 PM UTC
We recently had some issues with this. Couple things we did that helped.
1. Spaceball - If you are using one try stopping the driver and see if it improves the redraw rate. Had to buy all new spaceballs and update drivers for many here.
2. Cross-Hatching - Any section views were coming in with a cross hatch spacing of .001 mm or something tiny. The result was cross section drawings that had hundreds of thousands of tiny lines, which was essentially a solid block of cross hatches. Wrote a macro to set all spacing to '1' and it greatly reduced redraw times.
3. Work-Around - try moving the view you are working on to a second sheet, editing it there, and then moving it back.
Hope you fid the culprit
Graham
