OCUS Benchmark Test Error
- 2 replies
- 896 views
- Translate All
Wildfire 4.0 M170, operating system Windows 7 sp1
Tech support wants to be able to have some kind measured improvement for upgrades. Irecommended tomy IT guys the OCUS benchmark mark test.
We are having trouble getting the test to run, Pro E will exit and the last lines in the file will read as:
!Command ProCmdModelNewExe was pushed from the software.
~ FocusIn `dwg_create` `inp_model_name`
~ Activate `dwg_create` `psh_browse`
< 2 0.118519 178 0 0 100 1680 0 0 1050 13
~ Trail `UI Desktop` `UI Desktop` \
`DLG_PREVIEW_POST` \
`file_open`
~ Select `file_open` `Ph_list.Filelist` \
0
~ Activate `file_open` `Ph_list.Filelist` \
0
!%CEERROR: Trail file out of sequence at line 20890.
!End of Trail File
We also tried Windows XP 32 bit and 64 bit with the same result.
Anybodyknow what this error means?
Steve
