6-Contributor
On the issue of importing images from format templates
I am using Creo Parametric Release 9.0 and Datecode9.0.2.0
After importing images through object OLE in the format template, the image cannot be displayed when opened again, and even after creating a drawing template using the format template, the image cannot be displayed. What is the reason? How can I import PNG images with transparent backgrounds into the format template file?
    hadardorAnswer
    Fact A black or white background will display when image with transparent background is inserted as an Object in a format file is a working as designed behavior, refer to article :
    https://www.ptc.com/en/support/article/CS364138
    tbraxton
    it is not clear from your post if using transparency on import is part of the problem. This may help with the transparent background issue.
    Article - CS118311 - How to insert an image or transparent color image to a drawing in Creo Parametric (ptc.com)
    6-Contributor
    Thank you for answering my question. My main problem is how to insert a PNG image with a transparent background in the format file. I saw that it is possible to insert a PNG image with a transparent background in the drawing file, but in the format file, it seems that the image can only be inserted through OLE by inserting objects. I imported it through the built-in drawing software on my computer, and the background has become opaque and pure white.
    The above two images are the appearance of imported images in a format file. The transparent background of the image has changed to a white background
    The above image was imported from a drawing file with a transparent background
    ask PTC support to let you know if it is possible to instert png in a format with a transparent background.
    I guess such functionality is not implemented and you will have to use drawing template instead of format.
    hadardor17-PeridotAnswer
