Feb 24, 2011 11:41 PM UTC
Only one user out of hundreds can't access standard material directory
Only one usercan't access standard material directory
Using WF4.0 M162 and PDMlink 9.1 M030
User has been given different server access in the past to other facilities
Configuration is being directed to the defaultmaterials directoryi.e. W:\Proe64\text\materials\library.The company standard material directory isnoted in the config.supbelow.
Boot path and icon is the same as other users
It appears that the Windchill/ProE configuration isn't pointing to the correct config.sup file when booting; but only for one user.
The user took out the personal config.pro at the startup directory so path is not being changed but config.sup would overwrite it anyway.
UsersPro/E trail file is different than one with the correct path but doesn't leave much of a clue to the source of the problem.
!==Standards Directories ==
pen_table_filew:\pro_stds\plot_config_dir\table.pnt
pro_format_dirwtpub://Windchill/Libraries/CAD Standards Library/Formats
pro_material_dirwtpub://Windchill/Libraries/CAD Standards Library/Material
pro_symbol_dirwtpub://Windchill/Libraries/CAD Standards Library/Symbols
pro_surface_finish_dirwtpub://Windchill/Libraries/CAD Standards Library/Symbols/surffins
pro_dtl_setup_dirwtpub://Windchill/Libraries/CAD Standards Library/Configs
pro_format_dirwtpub://gdllsdsrvwdb061/Libraries/CAD Standards Library/Formats
pro_material_dirwtpub://gdllsdsrvwdb061/Libraries/CAD Standards Library/Material
pro_symbol_dirwtpub://gdllsdsrvwdb061/Libraries/CAD Standards Library/Symbols
pro_surface_finish_dirwtpub://gdllsdsrvwdb061/Libraries/CAD Standards Library/Symbols/surffins
pro_dtl_setup_dirwtpub://gdllsdsrvwdb061/Libraries/CAD Standards Library/Configs
pro_note_dirw:\pro_stds\note_dir\
pro_plot_config_dirw:\pro_stds\plot_config_dir\
pro_sheet_met_dirw:\pro_stds\sheet_met_dir\
pro_group_dirw:\PRO_STDS\group_dir
start_model_dirw:\PRO_STDS\start_files
20-Turquoise
Feb 24, 2011 11:59 PM UTC
On 02/24/11 16:41, Donald LeLievre wrote:
> Only one user can't access standard material directory
> Configuration is being directed to the default materials directoryi.e. W:\Proe64\text\materials\library. The company standard material directory is noted in the config.sup below.
> Users Pro/E trail file is different than one with the correct path but doesn't leave much of a clue to the source of the problem.
> *pen_table_file w:\pro_stds\plot_config_dir\table.pnt
> pro_format_dir wtpub://Windchill/Libraries/CAD Standards Library/Formats
> pro_material_dir wtpub://Windchill/Libraries/CAD Standards Library/Material
Does the user have a registered server named "Windchill" ?
Does the format directory work for this user?
I notice you have more than one windchill server listed.
> *pro_symbol_dir wtpub://Windchill/Libraries/CAD Standards Library/Symbols
> pro_surface_finish_dir wtpub://Windchill/Libraries/CAD Standards Library/Symbols/surffins
> pro_dtl_setup_dir wtpub://Windchill/Libraries/CAD Standards Library/Configs
> pro_format_dir wtpub://gdllsdsrvwdb061/Libraries/CAD Standards Library/Formats
Second Windchill server named "*gdllsdsrvwdb061" *defined here.
> *pro_material_dir wtpub://gdllsdsrvwdb061/Libraries/CAD Standards Library/Material
> pro_symbol_dir wtpub://gdllsdsrvwdb061/Libraries/CAD Standards Library/Symbols
> pro_surface_finish_dir wtpub://gdllsdsrvwdb061/Libraries/CAD Standards Library/Symbols/surffins
> pro_dtl_setup_dir wtpub://gdllsdsrvwdb061/Libraries/CAD Standards Library/Configs
> pro_note_dir w:\pro_stds\note_dir\
> pro_plot_config_dir w:\pro_stds\plot_config_dir\
> pro_sheet_met_dir w:\pro_stds\sheet_met_dir\
> pro_group_dir w:\PRO_STDS\group_dir
> start_model_dir w:\PRO_STDS\start_files*
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
