6-Contributor
November 25, 2016
"open file" dialog in Creo is not updated
The latest models and drawings from the network drive are not displayed on the Creo Workstation and can’t be opened. The File Explorer in the "open file" dialog in Creo is not updated. Only model versions are loaded, which were present with timestamp before Creo start.
If models are changed and saved and are recalled after deleting the memory, the old version is loaded. The new file version is present on the network drive, is not found from the Creo session.
After restarting the Creo session, all documents from the network drive are displayed and can be opened in Creo.
Infrastructure: windows 7 64Bit + windows10 64Bit Workstation / File Folder: Network LINUX Samba SMB NTFS mapped drive
I guess this problem is related to Samba system. I am not sure whether PTC supports such environment.
Maybe following config.pro options help:
nt_cache_dirs yes
dir_cache_max number_of_directories_to_cache
MH
