open .jt file in Creo parametric
Hello, I have .jt file of a tank and would like to convert it into a format which Creo can open and save. I tried saving it as NX .prt file in NX12 and open it in Creo but "this part cannot be retrieved" message pops up. Is there any other solution for this?
I'm not able to open .jt file directly on Creo because I do not have the plugin to do that. Hence I'm using NX 12 to open and convert .jt file.
What version of Creo are you using?
There is a compatibility issue that only certain versions of NX can be opened in certain versions of Creo.
Creo 3 only supports up to NX 8.5.
Creo 4 may only support NX 10 or possibly NX11.
Try importing the .jt file into an earlier version of NX, if you have it and try again.
I'm using Creo Parametric 4.0 and would be surprised if it cannot open NX 12 part files. Is there an option to import as NX 11 version using NX 12?
This seems like a can of worms when you dive into it.
On the surface, the only .jt configuration options are in exporting (intf... options).
But on other sites, Creo is noted as opening these files, but it doesn't even see them.
Do note that .jt files are facet files.
They have very little intelligence other than display information mapped to 2-1/2D graphics space from a 3D point cloud.
If you can open it in NX, you can output it as any of the accepted facet files and Creo will open it.
Looks like the .jt files I have does not contain any b-rep data which means cannot be opened in Creo directly, hence they are facet files as you said. I'm able to convert them into IGES format and then open in Creo but IGES is a dead format,does not contain much data, Do you suggest any better format than IGES or STEP?
StephenW
What was your expectation? You will not get any features or model tree history other than an import feature.
