when part is displayed in Creo window, Open System Window is not available in user interface.
You can add this command into Quick Access Toolbar, for example.
Follow the below process to open system window-
 1. Go to File - Configuration option - Select Quick Access toolbar - In Comman Search type "Open system window" - Add command in quick access toolbar.  - Close configuration option window.
2. Now, you can see open system window icon at the top in quick access toolbar.
Sumit Singh
