Opening Certain Files in Windchill
All,
Another one of those things that's been bugging me for a long time and I keep ignoring...
Does anyone notice when opening certain files in Windchill that it asks you if you want to check out or continue or make read only and your just browsing? What's up with that? I am assuming that these files have something unresolved about them? Maybe family table related? Also when saving...it asks me if I want to check out, continue or make read only and I have not touched the file. Anybody know what I'm talking about? I generally make them read only and move on.
WayneF
StephenW
There is something that wants to regenerate...external references...relations...I can think of any more...right off hand...but I like having a longer list...
We have it set so everything comes in a locked in the workspace and then I check out what I want to change. It eliminates most of these annoying prompts.
wfalco16-PearlAuthor
Yes. I lock them too. I have at times gone to the files to see what the issues are and I know I was stumped. One that I thought to be the culprit is recalculating mass properties?
StephenW
Only mass properties if you use a relation, such as weight=pro_mp_mass
Top down designs will want to regenerate parts due to references.
Merges and inheritance features
Do you think this PTC article could give some hints about the reasons a Creo parametric model may be causing an Update conflict:
https://www.ptc.com/en/support/article?n=CS32596
