Jun 24, 2014 6:19 PM UTC
Parameter/variable for Creo date code?
I'd like to update my start script for Creo thus that it checks which date code version is installed on the users computer (e.g. M040, M090...)
Is there a general parameter, which i can use to do this?
Markus
FPerezAnswer
Jun 25, 2014 6:09 AM UTC
hello, we are using a DOS script:(if somebody has a better way...maybe we can do an idea ?)
we install Creo in : C:\CAO\appli\Creo 2.0
The script:
SET DRIVE=C:
SET REP_CAO=%DRIVE%\CAO
IF EXIST "%REP_CAO%\Appli\Creo 2.0" SET CREO_INSTALL=%REP_CAO%\Appli\Creo 2.0
SET PARAMETRIC_INSTALL=%CREO_INSTALL%\Parametric
SET COMMONFILES_INSTALL=%CREO_INSTALL%\Common Files
:: *** Récupération du release installé de Creo
PUSHD %COMMONFILES_INSTALL%
FOR /F %%a IN ('DIR /d /b') DO SET RELEASE=%%a
POPD
SET COMMONFILES_INSTALL=%CREO_INSTALL%\Common Files\%RELEASE%
ECHO RELEASE: %RELEASE%
ECHO COMMON FILES: %COMMONFILES_INSTALL%
Best Regards
Jun 25, 2014 5:51 AM UTC
Markus,
let us assume that you call something like C:\PTC\Creo 2.0\Parametric\bin\parametric.exe inside your script.
To get Creo Parametric 2.0 date code, look for the name of subdirectory of C:\PTC\Creo 2.0\Common Files directory.
Martin Hanak
FPerez13-AquamarineAnswer
The script:
SET DRIVE=C:
POPD
Best Regards
Jun 25, 2014 3:23 PM UTC
Thanks Fabrice,
that's exactly the answer i was looking for
Best Regards
Markus
Jul 23, 2014 1:26 PM UTC
THANK YOU! We have been trying to figure this out for a long time.
Also for those moving to Creo 3.0 here is the new version.
We install to C:\PTC
So the Creo 3.0 folder is install to the above location.
SET DRIVE=C:
SET REP_PTC=%DRIVE%\PTC
IF EXIST "%REP_PTC%\Creo 3.0" SET CREO_INSTALL=%REP_PTC%\Creo 3.0
:: *** Recover Creo install release
PUSHD %CREO_INSTALL%
POPD
SET CREO_INSTALL=%CREO_INSTALL%\%RELEASE%
Feb 16, 2015 2:39 PM UTC
Thanks for the tip and examples that others provided.
I am using the command DIR /A:D /O:N /B instead to list only folders without the full path. The /D option (Wide List format, sorted by vertical column.) only controls the output format, and does not do anything since when /B option (Bare format (no heading, file sizes or summary).) is used then the wide list format is not used. To get only directories the option should be /A:D for file attributes of folders only. To sort by name the option /O:N can be used.
Example:
:: Define where Creo is installed (typically C:\Program Files\PTC\Creo 2.0)
set CreoLoadPoint=C:\Program Files\PTC\Creo 2.0
:: Define release build version
pushd "%CreoLoadPoint%\Common Files"
for /f %%a in ('DIR /A:D /O:N /B') do set CreoBuildVersion=%%a
popd
References:
Dir - list files and folders | Windows CMD | SS64.com
Pushd - change directory/folder | Windows CMD | SS64.com
Popd | Windows CMD | SS64.com
