2-Explorer
Nov 23, 2016 8:26 PM UTC
Piping and Cabling extension
I am having issues getting the cabling extension to work on my computer.  We have 2 fixed liscense for the product.  the cabling application is available on the applications ribbon, however, when i click the cabling icon, i get the file options licensing error, there are no floating options currently accessible.
is there something in my configuration that is messing this up?
Nov 24, 2016 7:01 AM UTC
Piping and Cabling extension license modules must be added to basic Creo license during launch command configuration.
If you skipped this step then you can edit parametric.psf file manually to achieve the same goal.
  • open parametric.psf file in Notepad
  • locate line beginning with ENV=CREOPMA_FEATURE_NAME=
  • add following numbers between parenthesis to get ENV=CREOPMA_FEATURE_NAME=NameOfYourLicense (48 57 61)
Explanation:
#FeatureName        Product
#48                  CABLING
#57                  HARNESS-MFG
#61                  PIPING
MH
Explanation:
#48                  CABLING
#57                  HARNESS-MFG
#61                  PIPING
MH
