Please Help. Wildfire 5.0 Node Locked install failing after windows installation
I hope some people are out there still using Wildfire or know what is wrong. My Pro/e was working fine but I had to do a clean install of windows 10 and then reinstall my Wildfire version for the DVD. Now I cannot get my Pro/E to install correctly. I get the frustrating error:
(-96) License server machine is down or not responding
This is a node locked installation and I have the license file. I have tried what I understand from this article
https://www.ptc.com/en/support/article/CS21768
Any help would be greatly appreciated. Kind regards, Justin
@JK_3224567 wrote:
Thank you Martin for you input,
I didn't install the PTC License Server since I want it node locked, so I don't have Imadmin_ptc service or FLEX net running on my machine. I double checked looking in the Task Manager.
I also checked the proe1.psf file and it looks correct. I added the top line as suggested in the article I mentioned in my original post.
ENV=PRO_ALLOW_FLEXJOB=true
ENV=PTC_D_LICENSE_FILE-=C:\PTC Files\license.txt
ENV=PROE_FEATURE_NAME=PROE_FoundationAdv ()
Regards, Justin
  • install License manager using setup.exe from Wildfire 5.0 DVD. Use C:\PTC Files\license.txt license file
  • when installation is finished, FLEXlm server for PTC service is available
  • to verify license availability launch ptcstatus.bat from FLEXnet installation (the path could be C:\Program Files\PTC\flexlm\bin\ptcstatus.bat)
  • when license is available then modify proe1.psf
    ENV=PTC_D_LICENSE_FILE-=7788@nameofyourpc
  • turn off Windows Firewall
  • start Wildfire 5.0
I hope you have your license file safely backed up.
1.] stop lmadmin_ptc service
2.] uninstall FLEXnet license manager
3.] edit proe1.psf file in PROE\Parametric\bin directory
The file must contain two following lines configured properly.
ENV=PTC_D_LICENSE_FILE-=full_path_to_license_file
ENV=PROE_FEATURE_NAME=PROE_license_name (optional module numbers if some exist)
Regards, Justin
Mahesh_Sharma
22-Sapphire I
@JK_3224567
Can you confirm that your license is Node - Lock license? Open your license in text editor and search for word "Server", if found license will be floating not locked. ANd if it is floating , you need to install license server.
Is Wildfire 5.0 supported on Windows 10?
Wildfire 5.0 is not supported but it works.
