plot
Again, since the latest Creo 4.0 M090 upgrade, the system is not reading or recognizing the print.pcf file. I have the printer specific .pcf file that I have used for years for my HP CP2025 Color Laserjet. Now when printing the geometry lines and format/title block lines print heavy (obscuring small details) and all dimensions and text are in fine lines. I have checked the config.pro to make sure everything is pointing to the correct places. I even took the .pnt file and set all lines to 1 without any change. We also have a Toshiba E-Studio 167 with it's own .pcf file and . pnt file it has the same problem. Any ideas as to the problem?
Mahesh_Sharma
22-Sapphire I
August 15, 2019
@Warren_M
Good to know that it's working fine now.. you can accept your last rely as the solution for post.
my suggestion ... report the problem to PTC Support.
Mahesh_Sharma
22-Sapphire I
August 15, 2019
@Warren_M
Is there any change in config file? Did you try placing the pcf on local disk if it was on map network drive?
Warren_M10-MarbleAuthor
The <printer> .pcf and the  .pnt files are located on a the local machine. I have called into PTC support to see if they can figure it out.
Thank you
Warren
