Possible to use Reconfigure to have one configuration that pulls a local license, and another that pulls a license from a license server?
I have a user who is working remote.  He has a laptop with a local license that works for most applications.  Occasionally he needs to use a license we only have on the license server as a floating license.  Is it possible to have two configurations; one that pulls from the local file, and the other that pulls from the license server?
Mahesh_Sharma
22-Sapphire I
September 13, 2016
Scott,
Yes, you can create two configurations for Creo start. This all needs to be done using reconfigure.exe which is in <Install dir>\parametric\bin.
Once you will execute reconfigure.exe move to second window > Add License server (which will provide additional license) > Next > Customize Application > Command Configuration > Add > Change Description and name of command > Have required license in left which is needed for that specific startup command > Ok > Ok.
This will create two commands and which user will execute Creo there will a window to select start command.
I hope this will help.
swalsh1-VisitorAuthor
This is exactly what I have tried.  Once the license server is installed however, the local license is ignored and it always pulls a license from the server.
Mahesh_Sharma
22-Sapphire I
September 13, 2016
Scott,
Try making changes for license priority in PSF files (available in bin folder).
Edit line for PTC_D_LICENSE_FILE
ENV=PTC_D_LICENSE_FILE-=7788@LOCAL_LICENSE_SERVER;7788@REMOTE_LICENSE_SERVER
Mahesh_Sharma
22-Sapphire I
September 20, 2016
Scott,
Did you manage to get it working?
