May 5, 2011 10:35 PM UTC
ProE file version checking tool?
ProE Gurus,
I have a large number of ProE files in folders which were saved using different versions of ProE (Wildfire 1 thru 3).
I want to rapidly identify the subset of those which were stored in versions prior to WF3.
Is there a tool available for this purpose? Perhaps a method using a tool like grep?
Thanks in advance. I will publish a summary of any methods that work.
Barry Schaeffer
Fluke
Everett WA
    20-Turquoise
    May 6, 2011 2:59 PM UTC
    On 05/05/11 17:35, Schaeffer, Barry M wrote:
    > ProE Gurus,
    > Barry Schaeffer
    > Fluke
    > Everett WA
    On Solaris this shell script will do this
    #!/bin/sh
    for file in *
    do
    version="`head -1 $file | awk '{print $9}'`"
    if [ "$version" -lt "2700" ]; then
    echo $file
    fi
    done
    What this does is loop thru all the files in the current directory and
    finds the version by taking the 1st line of each file (head -1 $file) pipe
    that to awk to extract the 9th field of that line. Since 2700 is Wildfire 3
    it then compares the version to that. If less than "2700" then we have a
    pre WF3 file.
    Randy Jones
    Systems Administrator
    Great Plains Mfg., Inc.
    1525 E North St
    PO Box 5060
    Salina, KS USA 67401
    email: -
    Phone: 785-823-3276
    Fax: 785-667-2695
    May 9, 2011 10:59 AM UTC
    Hi Barry,
    You can use my ProTrail tool with the -chkvers option.
    (download it here).
    Copy protrail.exe to the folder (or another folder which is in your PATH)Open a DOS prompt in the folderRun ProTrail:
    protrail -dontrun -chkversIt will deliver output like thisSmiley Tonguerocessing file 300709296.prt.1
    File 300709296.prt.1 was created with Wildfire 4.0 (M190)
    Processing file din_125b.prt.1
    File din_125b.prt.1 was created with Wildfire 4.0 (M140)
    Processing file din_6325-old.prt.1
    File din_6325-old.prt.1 was created with Wildfire 4.0 (M140)
    Processing file din_7991.prt.1
    File din_7991.prt.1 was created with Wildfire 4.0 (M140)Kind regards,
    Olaf Corten
    Olaf Corten
    CAD/PLM Manager
    Fico B.V.
    Ratio 6, Duiven
    Phone: +31 26 3196215
    Mobile: +31 644548554
    www.besi.com
    To: "Schaeffer, Barry M" <barry.schaeffer@fluke.com>
    Cc: "-" <->
    Date: 06-05-2011 16:59
    Subject: [proesys] - RE: ProE file version checking tool?
