Feb 28, 2012 2:39 PM UTC
ProE WildFire 4 and VC++ 2010 express edtion-configuration
Hello All,
I'm a newbie for proe customisation.I have been using "Proetoolkiy_GSG.pdf" file to run the "pt_install_test" application using Proe4 and VC++ 2010.I have followed all the steps given in the above mentioned pdf file.In VC++ 2010 I manged to configure my project platform to "x64" since I'm compling the files on 64-bit machine(Windows XP x64 OS).WhenI build the sample projectI can see all the".obj" files getting created,however my"pt_inst_test.dll" is not getting created instead I'm getting following errors.
1>LINK : fatal error LNK1181: cannot open input file 'bufferoverflowu.lib'
1>NMAKE : fatal error U1077: "C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\x86_amd64\link.EXE" : return code '0x49d'
1> Stop.
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.MakeFile.Targets(38,5): error MSB3073: The command "nmake /f make_install dll" exited with code 2.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Please help me out of this situation.
Thanks in Advance
Mar 7, 2012 6:36 PM UTC
Purchasing the Professional version of MSVC 2005 will make 64-bit compilations easier but you will still have to follow the PTC makefile examples to make sure you have the proper libraries and preprocessor definitions setup.
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image001.jpg@01CCFC5E.DC7740B0]
