Apr 15, 2010 8:01 PM UTC
ProEngineerStart() hangs when I supply a large command line argument.
All,
I am trying to start a session of Pro/ENGINEER with the following command
line which hangs Pro/ENGINEER.
C:\PTC\proeWildfire4.0\bin\proe3.bat -i:rpc_input +Log="C:\Documents and
Settings\z1087788\My
Documents\Dev\SherpaBulkLoader\DSSherpaBulkLoaderSvc\147.24.230.178.8000.1271360615.152\DSSherpaBulkLoaderSvc_147.24.230.178.8000.1271360615.152.log"
I specified a command line length of [_MAX_PATH+_MAX_PATH] which is
260+260 = 520. This command line is only 244 characters. Is there a limit
on what Pro/ENGINEER can handle for it's input arguments?
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (business)
+1 520.545.6399 (fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
