Dec 9, 2013 3:27 PM UTC
propagate attributes into other part
hello all,
what's your favorit way to share an attribute into another model?
let me explain:
in a skeleton, I have defined several attributes and dimensions that are necessary to use in the other components.
I can make a copy of geometry, lenght analysis saved in the tree model to reuse the information, but it's very hard to use.
in fact, instead of a copy of geometry, I would like to make a copy of attributes!
thanks for answering,
Ronan
RonanAnswer
Feb 14, 2014 11:18 AM UTC
Hi all,
finally this is the tip I used:
in the first part I create attributes associated to a sketch curve. These attributes are controled by a relation like:
BASE:CRV_ATTRIBUTES=BASE
with BASE is the name of the attribute and ATTRIBUTES is the name of the curve.
then on the other parts I add a copy of this geometry and I specify the reverse relation:
BASE=BASE:CRV_ATTRIBUTES
and it works!
thank to all for your answers
Dec 9, 2013 3:44 PM UTC
Have you tried using a layout?
Dec 9, 2013 3:52 PM UTC
I just re-read your question. You want to copy analysis features, etc. in that case an inheritance feature could be useful, depending on what features you want copied over. But I don't know if you would want to copy all of the features over from another model...perhaps therein lies the nature of your question? I guess I'm not sure what you are trying to do, exactly.
Ronan14-AlexandriteAuthor
Dec 9, 2013 5:06 PM UTC
hello Eric,
thank you to answer. The inheretance feature is not so a bad thing. But now I'm shure I was not clear; please try to understand with this example:
create a part, then its symmetric part. You will show all attributes. Modify or add a new attribute in the master model, there is no change on the DEPENDANT (!!!) symmetry.
the other use case is in a model, I would like to reuse the lenght information of a sketch in the assembly using this part. I easily can do it with a relation like
length=TOTAL_LENGTH:FID_217:0
with FID means the feature analysis in the model. But it creates external references
Ronan14-AlexandriteAuthorAnswer
Hi all,
and it works!
