3-Newcomer
Proper Windows Multi-monitor support
Creo does not follow the Windows convention of taskbar status following to the monitor where the window is located.  This causes slow downs in workflow, and is how every single other modern windows program works.  Can Creo be updated to follow this convention?
Catalina
Community Manager
Hi ​@PEngineer99
Thank you for your question. 
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Catalina | PTC Community Manager
MikeBennett
Hi ​@PEngineer99,
Perhaps you could share some more detail about this.  With up-to-date Windows 11 and using Creo Parametric 13.4.2.0, for the Taskbar settings for when using multiple displays “Main taskbar and taskbar where window is open” and “Taskbar where window is open” the Creo icon is shown on the appropriate monitor’s taskbar.
Mike
3-Newcomer
I have the setting “Taskbar where the window is open”.   This gif shows me clicking the taskbar where the main creo window is, then moving the main window to my other screen, and you see the creo icon stays on the first screen.  Super annoying behavior.
