Mar 7, 2011 8:21 PM UTC
Properties....
I bet I'm missing this, but is there a way to access the internal
properties Pro/E has set up? Such as ModelCheck file locations. You
can set this in the MC installation but if the location is non-readable
for some reason, then Pro/E defaults to a different location. My bet is
that it's just a %userpath%\mc..... style setup (hence nothing to
consistently grab), but I was wondering if anyone knew of a call similar
to System.properties but for the Pro/E app. I didn't see anything in
the userguide (but I could just be daft..........common error).
TIA,
Brian Krieger
Peterbilt Motors
Mar 14, 2011 3:02 PM UTC
The best answer that I could think of would be ProConfigoptGet. If the
property you're after exists then you can get access to it with that API
call. Otherwise, I'm not aware of any API that retrieves "internal"
properties.
PATRICK S WILLIAMS
Information Technology
Mechanical Engr Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (office)
+1 520.446.0244 (pager)
+1 520.545.6399 (fax)
6221 S Palo Verde Rd
Tucson, AZ 85706-5093 USA
www.raytheon.com
Follow Raytheon On
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
