PTC Creo parametric options
Hi !
I asking for help today in relation with the options. I would like to know to make the software remember of my own options.
As an example, everytime i open creo i have to enter the options and specify one more time that i want "make the sketching plane parallel to the screen"...
I save those options in a config.pro but it doesn't work...
Thank you all,
Léo
kdirth
Are you saving the config.pro file to the correct location?  CREO may not be saving it in the same place as it is loaded from.
config.pro recognized by Creo must be saved in following locations
  • <Creo 2.0>\Common Files\Mxxx\text directory
  • User HOME directory
  • startup directory set in Creo shortcut
MH
