Jan 29, 2010 7:13 PM UTC
PTC_D Error on Laptop
Good day all
We have an issue with a laptop, seems that the PTC_D doesn't want to
run.
The laptop has it's own FlexLM server and ran fine early this week, but
after traveling and plugging into different domains
Now we get an -15 error (host or port is different than lic file)
I have tried many things:
Release / renew
Checked laptop name against host name
Checked cpu id against lic file
Reran flexlm setup and reread lic.txt file
Reinstalled flexlm to new directory
Checked regedit / network card order to verify wifi card was second to
the internal nic
All above made no diff.
I am currently still looking into other options with hopes someone out
there has been there before.
I will post my fix
Jscott
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
__________________________________________________________________________________________________________________
Feb 1, 2010 5:06 PM UTC
You need to turn off media sensing.
