May 23, 2016 9:14 AM UTC
PTC Diagnostic Tool not sending data for One User
I am seeing a weird problem with the diagnostics tool. One specific user is not appearing in the Performance Advisor dashboard. When I investigate this specific users PC I find the following:-
  1. If I open the Diagnostics Tool and click on the Pending Data tab it shows the pending system information OK, but if I click on the PTC CREO PARAMETRIC tab the diagnostic tool just instantly closes with no error message and without showing and information.
  2. If I click the Send Now button (without clicking the PTC CREO PARAMETRIC tab) nothing happens.
  3. I have checked that the machine can connect by initiating a successful telnet session to the PTC server.
  4. There is a stack of unprocessed files in the AppData/Local/PTC/QualityAgent/UnprocessedFiles location.
  5. In the AppData/Local/PTC/QualityAgent/SentFilesLog location the QA_clienty_sentfiles_logs.log file has lines in it that list .json files with a comment saying problem in opening file.
  6. If I access my companies Performance Advisor dashboard in a browser, it states in the top left corner "Last updated: 3 days, 9 hours ago"
As I mention above, I've confirmed this is not a firewall problem by successfully creating a telnet connection.
Any ideas what is going wrong?
MarcoTosin
May 23, 2016 1:52 PM UTC
Tim,
I have a list of opened calls about Performance Advisor for Creo.
A couple of them is related to sent sessions not showing in my dashboard.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS221106
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS236266
To manually send sessions with Diagnostic Tools you must have Creo open (check in task manager if there is a CreoAgent.exe process).
Marco
May 23, 2016 3:18 PM UTC
Hi Tim,
It is interesting that it only affects a single user, and others can send successfully. This leads me to believe there is a problem on that machine specifically. Can you try shutting down Creo and PTC Diagnostic tools. Then rename the qualityagent folder, to force recreation. Then launch and exit a session of Creo. You should then see a new unprocessed folder with the newly created xml files. Then launch PTC Diagnostics and try 'Send Now'. If that is successful there is a problem with one of the files in your original unprocess folder, preventing a successful send.
Let me know what happens with this test, and we can decide if a TS case should be opened for a deeper look.
- Dan
tdraper1-VisitorAuthor
May 23, 2016 4:46 PM UTC
Hi Dan. This did the trick, looks like something in the unprocessed folder was causing the problem. Just waiting for the diagnostics server at the PTC end to update to see if the results appear.
By the way, can I force an update on the PTC server, or do I have to wait for it to decide when to update?
- Tim
May 23, 2016 4:37 PM UTC
Are they all on the same build?  Did you verify this one user is on the same build as the others?  I think there was a problem with builds M150 and M160.
