Oct 28, 2026 7:55 PM UTC
PTC.opt file
I am trying get one user our single Premium Design license, but it is not working. Are there any tricks in formatting the ptc.opt file so it will assign the license where I need it to go.
I have verified that the location is correct on the DAEMON line of the license file. I have formatted the line in ptc.opt as:
RESERVE 1 PROE_DesignPrmP:44 USER <uername>
We are  running Creo 12.4.3.0
Anyone have any ideas of what to try?
Oct 29, 2026 12:06 PM UTC
Hello Ben,
I would try this:
GROUPCASESENSITIVE OFF
GROUP DESIGNPRIME <user name ex. bloosli>
INCLUDE PROE_DesignPrmP DESIGNPRIME
BenLoosli23-Emerald IIIAuthor
Nov 2, 2026 6:20 PM UTC
Brian,
Tried that and it is still picking up the DesignAdvP which is what we want all but the one user to have. The DesignAdvP is listed first, then the DesignPrmP. If I put the DesignPrmP license first only the first user to log in for the day will get it.
I did experiment with that positioning and if I did a PTCflush, then started Creo, I might be lucky and get the DesignPrmP license but that is not always a sure thing, depending on who is picking up licenses.
Nov 2, 2026 6:26 PM UTC
Ben,
A few things to look for.
  • Wrong feature name
  • Wrong username
    • what shows up when doing an lmstat -a
  • Restarted Vendor daemon?
  • INCLUDEALL used elsewhere?
  • Any other conflicting rules?
KenFarley
Nov 3, 2026 12:57 PM UTC
Ben,
Is there a reason you can’t use something like
  1. All users get a .psf that points to the “everybody gets access to these” licenses.
  2. Specific “special” user(s) get an additional .psf that gives access to “special” license(s).
  3. Normal users don’t know about special licenses, only get common ones or nothing when they start up Creo.
  4. Special users get a menu when they start up Creo asking which license they want to use.
I’ve used this for years to avoid people inadvertantly or purposely snagging licenses they are not supposed to be using, like the Advanced Machining or Advanced Assembly equipped loadouts.
Nov 3, 2026 1:26 PM UTC
Ken,
I have done things like that in the past, but we use a custom launch program here that sets the features from the program and the users do not have permissions to edit their own parametric.psf file or put a different .psf file in the bin folder.
KenFarley
Nov 3, 2026 2:08 PM UTC
Okay. I seemed to remember you had a nice controlled setup - versions always match up, etc.
So I guess you’re forced to rely on the ptc.opt mechanisms and their opaque workings. Ah well.
Nov 3, 2026 3:00 PM UTC
Different company, different rules.
My last setup was very nice and a single load of Creo for all users from a server. Batch file controlled licenses and default files.
