Sep 26, 2011 5:53 PM UTC
PTC Quality Agent
Creo 1.0, F000
So, I installed Creo 1.0 to play with it a bit. I won't get to use it
for a year or more, likely, but I was curious. Looks pretty good,
frankly.
Along with Creo 1.0, I got something called 'PTC Quality Agent'. I've
dug through the KB at ptc.com and it seems like some sort of reporting
program to transmit system data back to PTC on a schedule (monthly by
default). There is a way to transmit it on demand, but no way to clock
the scheduled transmissions.
What I couldn't find was why PTC needs it sent on a regular basis.
Sounds handy for times when you're communicating to a tech support
agent, but why send it every month (other than data mining)?
Most of the data is harmless enough (Windows version, RAM, Video driver,
etc.) but it by default also transmits your host name and domain name.
You can override that information, but not the machine specs and you
can't turn of the scheduled transmissions.
Am I paranoid to feel uneasy about this?
Doug Schaefer
Oct 3, 2011 5:44 AM UTC
Dear Damian,
please let me completely disagree with you. Of course, not about your
request on completely abandoning the old fashioned menu manager but on
blaming systems like Unix for a poorly designed user interface. PTC is
the one who designed a user interface like the menu manager. It was
not the operating system that "requested" something like this.
I will remind you also that the most slick and stylish UI, is Apple's OS
which is a pure Unix system!
Vassilis Anagnostopoulos*
SPIDER SA
Industrial Area - Rodotopi
45500 - Ioannina
Greece
Oct 14, 2011 5:43 PM UTC
FYI
Just downloaded M010 and during installation made sure to un-check Quality Agent, but it still got installed...
In Reply to Doug Schaefer:
What Mike says is correct, but if it does get installed, it cannot be disabled per se.  It can be uninstalled through Windows however.
Doug Schaefer
Oct 17, 2011 6:17 PM UTC
Dmitry -
In order to support Student and Trial versions of Creo, a change was
made in Creo 1.0 M010 such that the Quality Agent is always installed.
The check box controls whether or not the Quality Agent sends reports
back to PTC. By unchecking it, you indicated that you did not want data
to be sent back to us, and therefore no such reports will be sent.
There is an FAQ forthcoming soon on the Quality Agent, and this topic
and others will be explained clearly there.
~ Mike
Michael M. Campbell
DVP, Creo Product Development
T +1.781.370.5039
