ptc wildfire 4.0 help file
I have trouble with the help files
When i ckcik on the aid buttom a window is opening " file ://_tml/useascii/no_help.htm can not be found Check path or web adress"
On system information , i see that no path is registred for PRO/HELP
Can someone knows where to solve thos problem ?
    HELP has its own installation medium. You have to install HELP from it.
    MH
